ise with parellel on wireless
                   Hi, I'm using ISE 1.2 and WLC 7.4.100
OSX is able to do dot1x authentication, after that, we turned on the parellel and used windows with bridge mode.
and it was able to get on the internet. and I want it not to. Is there any way to prevent pralellel on the internet?
Everyone's tags (4)
Re:ise with parellel on wireless
Are you seeing any additional auth attempts from the bridged mac address.
Sent from Cisco Technical Support Android App
Tarik Admani *Please rate helpful posts*
Re: Re:ise with parellel on wireless
No, it just goes to the internet.
I think WLC does not even know there is another PC behind PHYSICAL PC
Are you sure you are using bridged mode and not nat mode? It seems as if the wlc would have a dedicated client entry for each different mac address that associates the controller.
This link gives all the information of your query to block and allow internet through wireless bridge mode.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bba10d.shtml
342
