Issue with Network configuration - ACS 4113 Appliance
dpatkins
We are having issues with two particular devices. I am trying to remove and add the devices, but when I do a search and go to their IP, I receive.
Failed to edit blahblah.ourdomain.... Reason: The Host no longer exists.
How do I get rid of this so I can readd the devices?
Dwane
Daniel Laden
Level 4
Level 4
how many characters long is the host name. If longer than 32, you will not be able to modify it in the gui. Use the CSUTIL to delete it. Recreate it with fewer than 32 characters.
Daniel Laden
Level 4
Level 4
I appreciate the help. That was it. 32 characters.
Removed them and readded a much smaller name.
Dwane
Looks like this is a the same issue here but I am on a SE box and Putty into it I do not see the option for CSUtil, any ideas if this is possible on a SE box?
Yes, ACS SE doesn't support csutil. Please use RDBMS with solution engine and see if that helps.
Creating, Reading, Updating and Deleting AAA clients
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/configuration/guide/rdbms_sync.html#wp1011624
Regds,
JK
Do rate helpful posts-
~Jatin
