Juniper SSG TACACS+ Integration with ACS 5
kuenlo
I'm working on TACACS+ integration on Juniper SSG firewall with ACS 5, but failed login on the SSG. After checked the log on ACS, it passed the authentication. Do I need to import any dictionary file on the ACS 5 first?
Please advice,
Cheers,
Ryan
paul.linning
Hi , did you get any response on this I have the same issue with ACS 5.0  and SSG 320M  , get the same with both TACACS and RADIUS , Authentication fine but no login fails on box  ?
chinalfr2007
I was able to config SSG authenticate using RADIUS.  In order to work with RADIUS, I have to create RADIUS dictionary using netscreen dictionary found @ Juniper.  Attach the dictionary.
I'm not sure how to import, but I create the dictionary manually.
