License question going from 5.3 to 5.4
Lance Wendel
                   HI all,
I have couple of question regarding License when upgrading for a ACS 5.3x.
1) when upgrading from 5.3.0.40.1  -> 5.3.40.8 would you require license upgrade (I assume no as this is minor upgrade)
2) going from 5.3.x to 5.4.x would you require license upgrade (I assume no as this is minor upgrade too)
3) what is the process of applying the license, is it during the installation or after the installation (I guess for the point 1&2 this is not required)
kindly advice if I am incorrect here
thanks in advance
Lancellot
2 Accepted Solutions
Amjad Abdullah
You can use same license. But if you have to re-image then you will be asked to provide same license again.
Rating useful replies is more useful than saying "Thank you"
Check the release notes if you did not do that already. It will be also useful to you:
goo.gl/C6D2a4
Amjad Abdullah
goo.gl/C6D2a4
