Licensing question on C1121 ACS appliance
Hi all,
I have the scenario as below:
01. I have one customer unit C1121 ACS system shipped with version 5.1. The customer buy the base license and large deployment license along with the purchase.
02. Fact is i have manually upgrade the system to version 5.3.0.40, and applying a trial license for it for administering the appliance.
My question is:
a. If i now using the purchased base license and large deployment PAK to activate the system, would it still valid for me to continue using Version 5.3.0.40?
thanks
Noel
1 ACCEPTED SOLUTION
Silver
Yes, the ACS 5.x is a licensed-based application. You can install your licenses on any ACS 5.x version without any problems. The licenses are not version specific.
If this was helpful please rate.
Regards.
Silver
Regards.
Hi Carlos,
Thanks for the info !!!
Noel
389
