logging PIX 525 logons & commands in ACS
linnea.wren
I have Cisco ACS 3.3. I have a PIX 525, version 6.3(5). I have the PIX authenticating in TACACS, configured on the ACS box.
But, the PIX logons don't appear in TACACS Accounting Log on the ACS box. I have a 6509 (catOS), and a 3745 (IOS 12.3) doing TACACS authentication off the ACS box - for the 6509 & 3745, logon events DO appear in TACACS accounting log on the ACS box.
PIX logons DO appear in the Passed Authentications log in ACS.
Further, I would like to get commands done on the PIX to be logged on the ACS box. I've achieved this with the 6509 & the 3745.
I checked out "aaa accounting ..." on the PIX box. Did this :
aaa acc include telnet inside 0 0 TACACS+
Managed to log a user making a telnet connection to the outside (which is what documentation seemed to be saying, but one can hope...)
Here's the relevant part of PIX running-config (w/out the aaa accoun... command from above - took it out since it didn't work) :
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server TACACS+ (inside) host 10.10.1.231 <key> timeout 10
aaa-server LOCAL protocol local
aaa authentication telnet console TACACS+
In ACS, Interface Configuration, TACACS+ (Cisco), TACACS+ Services, I have check marks on PPP IP, Shell (exec), and PIX Shell (pixshell).
I looked in ACS for other things that might not be enabled, but couldn't recognize anything else as relevant.
Help?
gfullage
PIX does not support command and administrative accounting until v7.0, which is why you can't find anything in the 6.3 documentation about it :-)
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_70/70_rn/pix_70rn.htm#wp162402 (the Enhanced AAA Section)
Command Reference's for this is here:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/cref_txt/ab.htm#wp1381036
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/cref_txt/ab.htm#wp1381150
