Community Member
MAB on Voice Vlan for non-Cisco phone
I try to do MAB authentification for a non-cisco phone. My port config is :
switchport mode access
switchport nonegotiate
switchport voice vlan 41
dot1x mac-auth-bypass
dot1x pae authenticator
dot1x port-control auto
dot1x host-mode multi-host
dot1x guest-vlan 100
dot1x auth-fail vlan 100
no cdp enable
spanning-tree portfast
It seems that the 2960 switch doesn't even try to do MAB on voice vlan because it try to do CDP.
If i don't use voice vlan, the phone can authenticate with MAB but I cannot connect a pc behind the phone
Re: MAB on Voice Vlan for non-Cisco phone
Would not recommend multi-host mode, since it intentionally allows port piggybacking.
You need MDA. See here:
http://www.cisco.com/en/US/tech/tk389/tk814/technologies_configuration_example09186a00808abf2d.shtml#MDA
This will allow you to MAB the phone, treat it as a phone, then do the same for the PC as well.
HTH,
Community Member
I've tried this technote, the problem is when command 'switchport voice vlan' my switch automaticaly try to detect the phone via cdp and doesn't fallback to authenticate phone via MAB
I'm using catalyst 2960 12.2.25 SEE3
If you have MDA enabled it won't. Also, I thought you have non-cisco phones? ;-).
HTH,
1224
