MAB with ACS 4.2 and NAP
Hellow
I'm using NAP's and want to use MAB as well. Right now i use the ACS Util to add MAC addresses to the right ACS Groups. But when using NAP's, I need to configure MAB under "Authentication" in the profile. Right there i also have to add all the MAC addresses (Add MAC Addresses into Internal DB). But I already added them by the script. Isn't there a was to bypass this ? Just select a ACS group to check the MAC addresses ?
Remco
1 REPLY
Re: MAB with ACS 4.2 and NAP
Hi Remco,
Please visit the below listed link:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_
for_windows/4.1/configuration/guide/noagent.html#wp1083264
You'll find a section called "Default Action", the MAC address that are not
found on local database/LDAP, are assigned to the group selected in this
section.
If we do not want all the MAC address to go through MAB, then select a group
for Default Action, and disable it.
JK
~BR Jatin Katyal **Do rate helpful posts**
451
