11-19-2003 06:41 AM - edited 03-10-2019 07:34 AM
Is there any way to get the cisco router to use MSCHAPv2 for telnet/enable authentication?
What I have set up now:
aaa new-model
aaa authentication login telnet group radius enable
enable secret xxxxxxxxxx
enable password test
radius-server host XXXXXXXXX auth-port 1812 acct-port 1813
radius-server key ciscotest
11-19-2003 08:11 AM
MSCHAPv2 is a way of authentication for PPP connections between a computer using a Microsoft Windows operating system and a network access server (NAS).
Therefore , using MSCHAPv2 for telnet/enable authentication isn't possible (Only PPP connections)
11-19-2003 09:07 AM
This would be for the following command:
line vty 0 4
login authentication telnet
trying to use a Micorosoft IAS server with active directory to authenticate login attempts on a cisco router. I get an error message on the IAS server that the router is using PAP authentication. There is no way to force the router to use CHAP in this scenerio?
