NAC replacement procedure
vijay kumar
Level 2
Level 2
Hi Experts ,
Our NAC 3315 is not working due to some hardware failure . So we are going to replace that .Hence kindly confirm the steps to take backup and procedure to install it?
Vijay.
Since there seems to be no method of performing a CLI backup on the 3315 appliance, we must go the route of the workaround. This may seem a bit out there, but is the only way that I can see a backup being created without using the WebGUI.
First and foremost, do you have any IP access to the NAC appliance?
If not, quit reading and contact TAC.
If you have setup backups in the past, they are stored in the /guest/bakcups directory and can be transferred via FTP, SFTP, etc..
If not, then download an upgrade file that is newer than the release you are running (if you are running the latest release, download the upgrade file to get to that release). In this case, v2.1.  Transfer the file to your repository and initiate the upgrade on the NAC Guest server.
Note Before the 2.1 upgrade, a backup snapshot of the existing 1.x or 2.0.x database is automatically created and stored in the /guest.bak directory. In the event of an upgrade failure, Cisco recommends making a local backup of this directory.
http://www.cisco.com/en/US/docs/security/nac/guestserver/release_notes/21/gsrn21.html#wp111257
Otherwise, I am at a loss on this issue.
Please Rate Helpful posts and mark this question as answered if, in fact, this does answer your question.  Otherwise, feel free to post follow-up questions.
Charles Moreton
7 Replies 7
Hi Anas,
Thanks for the reply . We arehaving only guest nac server 3315 . The above said links points to some NAC CAM . I m not sure on this . Could u plz explain.
Vijay.
Gurpreet Puri
Hi Vijay,
Below is the link which explained how to backup and restore the guest nac server 3310:
http://www.cisco.com/en/US/docs/security/nac/guestserver/configuration_guide/20/g_backup.html
Gurpreet S Puri
(Please rate helpful posts)
Regards, Gurpreet S Puri **************************** Keep Smiling, Peace :) **************************** (Please Rate Helpful Post)
Hi Gurpreet ,
Thanks for your reply . Is there a way that we can take backup from CLI mode of NAC?
Vijay
Which software version of the NAC Guest Server are you running?
Hi charles,
We are running 2.0.2
Charles Moreton
