Need Help to Create ACS PEAP for CA on win2003
We've encounter the issue of keys as exportable so as adivse from the Enable of https wiht certificate configuration for CISCO ACS Admin Sessions.
Can any one give some hought on this matters.
We are unable to do Certificate Template to Issue ...??
Create a New Certificate Template
Complete these steps:
Choose Start > Run > certmpl.msc. 1.
Right−click Web Server template. 2.
Choose Duplicate Template. 3.
Give the template a name, such as ACS. 4.
Click the Request Handling tab. 5.
Choose Allow private key to be exported. 6.
Click the CSPs button. 7.
Choose Microsoft Base Cryptographic Provider v1.0. 8.
Click OK.
Note: All other options should be left as default.
9.
Click Apply. 10.
Click OK. 11.
12.
Right−click Certificate Templates. 13.
Choose New > Certificate Template to Issue. 14.
Choose the new template you created. 15.
Click OK. 16.
Restart the CA.
1 REPLY
Silver
Re: Need Help to Create ACS PEAP for CA on win2003
To create ACS PEAP follow the below steps:
Click System Configuration, and then click Service Control.
Click Restart to restart the service.
To configure PEAP settings, click System Configuration, and then click Global Authentication Setup.
Check the two settings shown below, and leave all other settings as default. If you wish, you can specify additional settings, such as Enable Fast Reconnect. When you are finished, click Submit.
Allow EAP-MSCHAPv2
Allow MS-CHAP Version 2 Authentication
278
