01-08-2014 07:32 AM - edited 03-10-2019 09:15 PM
we are configuring all our network switches with Radius authentication ,we are able to roll out on most of the switches successfully ,but the cisco WS-C3548-XL (C3500XL-C3H2S-M) switch with IOS Version 12.0(5)WC8, RELEASE SOFTWARE (fc1) is not accepting our default configuration commands as below
aaa new-model
aaa authentication login default group radius local
ip radius source-interface VlanXX ( Specify Management Vlan)
radius-server host XX.XX.XX.XX auth-port 1645 acct-port 1646 key *******
radius-server source-ports 1645-1646 aaa new-model
Any help regarding this is appreciated.
Solved! Go to Solution.
01-08-2014 07:38 AM
Hi Kalyan,
What is the error message that you receive?
See if this helps:
https://supportforums.cisco.com/thread/218313
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
01-08-2014 07:38 AM
Hi Kalyan,
See if this helps:
--Dalai Lama**
Ed
01-08-2014 07:46 AM
I do not know if this is just an artifact of cut and paste for this message or whether it is really what you are using, but this line would certainly be rejected for invalid syntax if you did input it to a switch
If it is just a cut and paste issue then I agree with Ed that we need more information about what part is not accepted and any messages that are generated. I would also appreciate some clarification about whether you are experiencing this problem on a single particular switch or whether you are experiencing it on several switches all of which are WS-C3548-XL (C3500XL-C3H2S-M)
Rick
01-08-2014 07:50 AM
Hi Rick,
that was a typo and yes it is happening on all similar switch models.
01-08-2014 07:46 AM
Hi Ed ,
it wont give any error i see it does not recognize the command format
Switch(config)#aaa new-model
Switch(config)#aaa authentication login default group radius local
Switch(config)#$auth-port 1645 acct-port 1646 key ******
% Invalid input detected at '^' marker.
Switch(config)#
01-08-2014 08:01 AM
Kalyan,
What do you get for :
"radius?"
try to use "?" to fill the command.
the syntax might be different on this guy.
--Dalai Lama**
Ed
01-08-2014 10:30 AM
Ed,
Here you go
Switch(config)#radius ?
% Unrecognized command
Switch(config)#
i just want to know which is the syntax equivalent of the below
radius-server host 172.26.0.11 auth-port 1645 acct-port 1646 key *****
01-08-2014 10:43 AM
What do you get if you try this
Switch(config)# ?
Rick
01-08-2014 10:58 AM
please see below
Switch(config)#?
Configure commands:
aaa Authentication, Authorization and Accounting.
access-list Add an access list entry
alias Create command alias
arp Set a static ARP entry
banner Define a login banner
boot Boot Commands
buffers Adjust system buffer pool parameters
cdp Global CDP configuration subcommands
cgmp Global CGMP configuration commands
class-map Configure QoS Class Map
clock Configure time-of-day clock
cluster Cluster configuration commands
default Set a command to its defaults
default-value Default character-bits values
downward-compatible-config Generate a configuration compatible with older
software
enable Modify enable password parameters
end Exit from configure mode
exception Exception handling
exit Exit from configure mode
file Adjust file system parameters
help Description of the interactive help system
hostname Set system's network name
interface Select an interface to configure
ip Global IP configuration subcommands
line Configure a terminal line
logging Modify message logging facilities
mac-address-table Configure the MAC address table
map-class Configure static map class
map-list Configure static map list
no Negate a command or set its defaults
ntp Configure NTP
policy-map Configure QoS Policy Map
priority-list Build a priority list
privilege Command privilege parameters
queue-list Build a custom queue list
rmon Remote Monitoring
scheduler Scheduler parameters
service Modify use of network based services
shutdown Shutdown system elements
snmp-server Modify SNMP parameters
spanning-tree Spanning Tree Subsystem
stackmaker Specify stack name and add its member
tacacs-server Modify TACACS query parameters
tftp-server Provide TFTP service for netload requests
time-range Define time range entries
udld Configure global UDLD setting
username Establish User Name Authentication
vmps VMPS settings
vtp Configure global VTP state
01-08-2014 12:36 PM
Ed ,
See if this helps:
i tried this on one of the switch and it worked ,i am trying on the other switches.
01-08-2014 12:59 PM
Awesome, lemme know how it goes..
Good to know.
--Dalai Lama**
Ed
