No conversation between ACS 3.2 and ACE 5.1 (needed for PEAP)
i try to connect with the ACS 3.2 to the ACE 5.1 on the same server with no succes.
have installed the Agent for the ACE5.1 on the same Server and Test-authentication works fine.
If i made authentication on cisco secure database it works fine to.
When i change to authentication on RSA Securid Token Server(ACS 3.2) just get error message ,,external DB authentication failed,, .
Client and ACS are working with PEAP.
Thanks for every help .... is it possible to start a debug on the ACS or ACE server to see what informations are sending to the servers , or other idee?
Thanks Harald
1 REPLY
Silver
Re: No conversation between ACS 3.2 and ACE 5.1 (needed for PEAP
The following are some of the debug commands that you can use,
debug aaa authen
debug aaa author
debug aaa per-user
debug aaa subsys !! not supported by all releases
debug ppp neg
debug tacacs
debug tacacs authentication !! not supported by all releases
debug tacacs authorization !! not supported by all releases
debug tacacs events !! not supported by all releases
debug modem
You can also create a output called package.cab, which is very useful for troubleshooting.
155
