No TACACS+ Administration Reports after upgrade to ACS 4.1
I was running ACS 4.0 demo version. Everything was running fine.
After upgrading and keeping the old configuration, I can't see logs in the TACACS+ Administration Reports. I kept the configurations on the router and switch the same, so I believe that the problem resides in the ACS software.
I tested some debug, and it seems that the router is sending the command that is being typed to ACS.
Here is the config I?m using:
aaa new-model
tacacs-server host 192.168.X.X key XXXXXXXXXXX
aaa authentication login telnet group tacacs+ enable
aaa authentication login console enable
aaa authentication enable default group tacacs+ enable
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection telnet start-stop group tacacs+
line con 0
authorization exec NO-AUTH
login authentication console
line vty 0 4
authorization exec AUTH
login authentication telnet
aaa authorization exec AUTH group tacacs+ none
aaa authorization config-commands
aaa authorization exec NO-AUTH none
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
1 ACCEPTED SOLUTION
Re: No TACACS+ Administration Reports after upgrade to ACS 4.1
This is a known issue, you need to apply patch ACS 4.1.1.23.5 to fix the issue.
Patch for appliance is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
Patch Name : ACS 4.1.1.23.5 accumulative patch
That should fix the issue,
Jagdeep
Note: If that answers your question, then please mark this thread as resolved, so that others can benefit from it.
Jagdeep
Hi Jagdeep .
Thanks for the reply.
I updated ACS and it's working now.
Pinto,
Nice to know. Please mark this thread as resolved, so that others can benefit from it.
~JG
170
