per user ACL's and QoS
rui.silva
I there !!1
I have a network that uses MS IAS for Radius auth in a wireless network. I'd like to setup 802.1x in all the switchs we have. The auth thing is simple (I hope). I've Found information on assigning user to a Vlan thru a radius response, but i'm trying to go beond that.
I'm trying to find if it's possible to use per user ACL's in 2950 Switches?
I've been searching, and I found DACL's, but all the nformation only points to PIX/ASA/Router products. Is it possible to use this in switches?? or theres something like his.
I Want to stop traffic in this switchs, so it doesn't clutter the network. And because a have several groups of users inside a master group, i.e.: I have TEachers and then inside that I have Mecanics Theachers, Computer ENG Teachers, ... You get the picture.. :)
Is it possible and where can I find Information. (IOS version no problem, I'll buy the version needed)
Rui Silva
Instituto Polit?cnico de Leiria
Portugal
sbilgi
Level 5
Level 5
he following example shows that per-user QoS is being configured using the AAA policy name "policy_class_1_2":
class-map match-all class1
match access-group 101
class-map match-all class2
match qos-group 4
policy-map policy_class_1_2
class class1
bandwidth 3000
queue-limit 30
class class2
bandwidth 2000
class class-default
bandwidth 500
peruser_qos_1 Password = "lab"
Service-Type = Framed,
Framed-Protocol = PPP,
Cisco:Cisco-avpair = "ip:sub-policy-In=ssspolicy"
!ssspolicy in the above line is the name of the policy.
peruser_qos_2 Password = "lab"
Cisco:Cisco-avpair = "ip:sub-policy-Out=ssspolicy"
