Ploblem with 2950 and ACS
Hi all,
I've configured the 2950 as below and configured ACS correctly and I can login to the 2950 using this config, the problem lies after I go into enable and try any command I get the following error Command authorization failed.
What have I missed out of the config that will allow me to run any commands?
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa authorization network default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
tacacs-server host ***.***.***
tacacs-server key 7 ***********
Thanks in advance.
Bruno
1 ACCEPTED SOLUTION
Bronze
Re: Ploblem with 2950 and ACS
Hi friend,
The switch's AAA looks ok, maybe you need to take a look at your ACS.
Check the following info, where you might need to apply it into your ACS config:
http://www.cisco.com/en/US/products/sw/secursw/ps5338/products_configuration_guide_chapter09186a00801fd6fc.html#wp676529
If it helps, please rate or ask another question.
Rafael Lanna
Bronze
Hi friend,
Rafael Lanna
You may want to check the account's assigned privilege level.
123
