Privilege Level authentication
abbas.ali
There are 15 levels of privilege. Is there any list to find out what level provides what right? I looked into CCO, but no specific thing.
kthanuva
Hi Abbas,
The privilege commands depends on the IOS versions.And the list of commands is a huge one.Better u can use ? and see for each privilege.
This Privilege option is used mainly for restrict the access of commands
please find the below link
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800d980c.html#1027108
Kiruba
Hello Abbas,
Actually there are 3 default levels of privilege on the router: 0, 1 & 15. Level 2-14 are user defined. Level 2-14 inherits all the level 0 & 1 commands.
Level 15: all commands are allowed
Level 1: all the user mode command
Level 0: only 5 commands: disable, enable, exit, help, and logout
Here is the link that has explaination of this:
http://www.cisco.com/warp/public/480/PRIV.html
If you want to know how to assign level 15 commands to level 2-14 locally on the router, you can refer to my explaination on this post:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.ee97017
I hope it helps ! Thanks,
Mynul
