12-02-2005 04:55 AM - edited 03-10-2019 02:23 PM
Folks,
I have an eval copy of ACS 3.3 working fine on a W2K server.
However, I installed another copy on a win2003 server and I am having real difficulty just adding an AAA client. I tried it originally with ACS 3.3, then upgraded to ACS 4.0 to see if that would resolve the issue.
I get an error saying "Radius key value must not be blank" even though I have put something into the Radius key field.
Aside from this when moving around the GUI I invariably get page cannot be displayed errors. The only way round this is to close the Browser and launch the GUI again.
Has anyone else experienced these symptoms?
Thank.
12-08-2005 09:33 AM
For adding a AAA client to ACS refer to the following url:
And follow the steps given the document.
02-24-2006 03:11 AM
I am also having the exact same symptoms, did you ever resolve the issue.
Best regards
02-28-2006 06:41 AM
Luckily,
i had another server at my disposal. I used it and it worked fine. Don't know what the difference was as these were both 2 brand new Dell servers with win 2003 pre installed.
02-28-2006 08:55 AM
I managed to sort it out! If you come across it again, upgrade to the latest version of Java from the Sun website and this seems to resolve any of display issues and blank radius key issue!
Cheers
