12-16-2009 09:22 PM - edited 03-10-2019 04:51 PM
I'm following the instructions to upgrade from ACS 5.0 to 5.1
But I can't get past the first step:
Step 1 Install the ACS 5.0 patch:
Issue the following acs patch command in the EXEC mode to install the ACS patch:
acs patch install patch-name.tar.gpg repository repository-name
Here is my output:
***/admin# acs patch install 5-0-0-21-9.tar.gpg repository mytftp
chmod: cannot access `*.sh': No such file or directory
Error: Failed to open patch 5-0-0-21-9.tar.gpg
It downloads the patch ok via TFTP, but can't install it.
Can anyone help?
Solved! Go to Solution.
12-16-2009 11:58 PM
There are problems in 5.0 with using tftp for file transfers that exceed 32Mb. There can also be some issues with ftp servers that exceed this limit.
I recommend to retry using alternative repository type. For example ftp or a repository local on the server.
12-17-2009 08:21 AM
You need to use and FTP server as repository I suggest using filezilla server is free and usefull.
Please see attach document that will explain you how to upgrade your ACS.
Hope this help!
Have a great weekend!
12-16-2009 11:58 PM
12-17-2009 08:21 AM
Hope this help!
04-29-2010 02:04 AM
ACS 5.1's TFTP seems to be broken, even under 32 MB:
csacs/admin# copy tftp://192.168.159.1/5-1-0-44-1.tar.gpg disk:
csacs/admin# dir
Directory of disk:/
10660640 Apr 29 2010 08:56:05 5-1-0-44-1.tar.gpg
16384 Apr 29 2010 07:34:04 lost+found/
Usage for disk: filesystem
54554624 bytes total used
4867284992 bytes free
5185241088 bytes available
csacs/admin# copy ftp://192.168.159.1/5-1-0-44-1.tar.gpg disk:
Username: ftp
Password:
csacs/admin# dir
Directory of disk:/
10660971 Apr 29 2010 08:57:57 5-1-0-44-1.tar.gpg
I couldn't install the patch with tftp (not surprisingly).
