12-18-2013 01:36 PM - edited 03-10-2019 09:12 PM
Is there a way to purge endpoints automatically from the RegisteredDevices endpoint identity group? So If an endpoint is registered using the self-provisioning flow, I would want that user to have auth-authenticated access for 24 hours, then they must re-authenticate, therefore their device cannot be in RegisteredDevices after 24 hours. Thanks.
Solved! Go to Solution.
12-18-2013 08:56 PM
Hi Josh,
A feature request is filed for the same under this id CSCua70707. Currently the only possible way I see is to manually delete the endpoints by checking the reports of endpoints that were registered and also profiled .
12-18-2013 08:56 PM
Hi Josh,
12-19-2013 05:16 AM
Thanks nginjupa. Do you know if you can view this endpoint group from the CLI? Maybe I could create a script. Otherwise it looks like I will need another option.
12-20-2013 07:25 AM
You could try to use the REST API to manage end points.
Cheers
12-20-2013 09:29 AM
I had this bug raised with TAC and have worked with the TME on a building a business case behind this feature. Basically my use case was to allow guest users to register without having to run through the CWA process everytime they are reassociated. I was told that this feature will be released in 1.3, however in order to help TAC prioritize their feature enhancements I would advise anyone requesting this feature please open a tac case and have their case attached this bug.
Essentially to goal is to set timers to specific identity groups so that the endpionts can be purge "x- amount of days without connecting to the network", it may take some time to get that exact feature but setting a definite timer of every 30 days is much better to have users periodically get redirected but help keep the level of the database fairly low.
Tarik Admani
*Please rate helpful posts*
