10-15-2008 02:17 PM - edited 03-10-2019 04:08 PM
Can you use RADIUS to authenticate commands in a Cisco router? I have done it with TACACS+ but can't do it with RADIUS. I mean to give administrators access to only show commands for example, etc...
Solved! Go to Solution.
10-15-2008 04:29 PM
That feature only works with tacacs and not radius.
Radius is not designed to do that.
~JG
Do rate helpful posts
10-15-2008 04:29 PM
~JG
10-17-2008 01:27 PM
Thank you for your response!
