06-30-2014 05:01 PM - edited 03-10-2019 09:50 PM
Hi Community,
I have a few questions on ISE functionality so here they go.
I would like to have only one open SSID with a limit of three devices per user, these users are from the internal database. The flow would something like this: the users connects to the open SSID and then is redirected to the guest portal, then after registration they should have access to internet and some internal resources. They have to be limited to only three devices per user and no Dot1x or anything like that would be used. So It would have to be some kind of security by identity but not with anyhting like Active Directory or anything. Can this be done?
Are SCEP certificates mandatory for this process?
I would also like to use this a a wired policy, so I guess MAB can be used in both scenarios?
Thank you
06-30-2014 07:47 PM
Refer "Limiting the Number of Personal Devices Registered by Employees" from
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_mydevices.html#pgfId-1106992
07-01-2014 10:13 AM
07-01-2014 10:14 AM
