RADIUS Probe on WLC for ISE
JHILL2
I am doing a Proof-of-Concept for wireless, and I'm getting the infamous "Unknown" endpoint for a device that should be getting profiled as a Windows-Workstation based on the info that I received from Identity-Endpoints section.  My question is whether it is possible pull out the information from the attribute list of the endpoint (such as tcp port 135) to use as a profile?
Here are the attributes:
Endpoint
* MAC Address
* Policy Assignment
Static Assignment
* Identity Group Assignment
Static Group Assignment
Attribute List
135-tcp msrpc
139-tcp netbios-ssn
3389-tcp            ms-term-serv
445-tcp microsoft-ds
ADDomain         truncated
AcsSessionID    ise-poc/133205055/184
Airespace-Wlan-Id          10
AuthState          Authenticated
AuthenticationIdentityStore         AD1
AuthenticationMethod     MSCHAPV2
AuthorizationPolicyMatchedRule truncated
CPMSessionID  0a64001d00000005502568b6
Called-Station-ID            64-d9-89-43-09-70:NACTEST1
Calling-Station-ID           18-3d-a2-92-0a-ec
DestinationIPAddress
DestinationPort  1812
Device IP Address
Device Type       Device Type#All Device Types#WLCs
DeviceRegistrationStatus            notRegistered
EapAuthentication          EAP-MSCHAPv2
EapTunnel         PEAP
EndPointMACAddress    18-3D-A2-92-0A-EC
EndPointMatchedProfile Unknown
EndPointPolicy  Unknown
EndPointProfilerServer    ise-poc
EndPointSource RADIUS Probe
ExternalGroups  ad.tdfadfa.org/departments/is/groups/sms-remote\,truncated
FQDN   lc20-isnetwrk03.ad.xxxxxx.orgg.
Framed-IP-Address
IdentityAccessRestricted            false
IdentityGroup     Unknown
IdentityPolicyMatchedRule          Default
LastNmapScanTime       2012-Aug-10 16:30:41 CDT
Location            Location#All Locations#
MACAddress     18:3D:A2:92:0A:EC
MatchedPolicy   Unknown
MessageCode   5200
Model Name      Unknown
NAS-IP-Address            truncated
NAS-Identifier    truncated
NAS-Port          13
NAS-Port-Type  Wireless - IEEE 802.11
NetworkDeviceGroups    Device Type#All Device Types#WLCs, Location#All Locations#truncated
NetworkDeviceName      WLC09
NmapScanCount            2
OUI       Intel Corporate
PolicyVersion    4
PostureAssessmentStatus         NotApplicable
RequestLatency 54
Response          {User-Name=foo\\webb; State=ReauthSession:0a64001d00000005502568b6; Class=CACS:0a64001d00000005502568b6:-poc/133205055/184; Termination-Action=RADIUS-Request; MS-MPPE-Send-Key=9c:b0:32:f4:ec:35:91:8a:6a:fc:87:05:ba:6a:4a:3c:fd:7e:3a:bb:ff:dc:c6:cd:36:ed:14:63:3b:88:34:18; MS-MPPE-Recv-Key=16:62:80:7d:6f:1e:09:5f:24:ed:f5:5e:c5:af:7d:fb:ef:95:c4:12:f8:55:f8:52:da:dd:b0:7b:9f:69:04:ce; }
SelectedAccessService  Default Network Access
SelectedAuthenticationIdentityStores       AD1, Internal Users, Internal Endpoints
SelectedAuthorizationProfiles      PermitAccess
Service-Type      Framed
Software Version            Unknown
StaticAssignment          false
StaticGroupAssignment  false
Total Certainty Factor     0
attribute-52        00:00:00:00
attribute-53        00:00:00:00
cisco-av-pair      audit-session-id=0a64001d00000005502568b6
ip          truncated
operating-system           Microsoft Windows XP SP2 or SP3
Tarik Admani
James,
That is possible but do you have the dhcp probe enabled and have you thought about setting up an ip helper statement or assigning the ISE node as one of the dhcp servers on the WLC?
There is a built in check such that if the dhcp class identifier contains MSFT will profile the endpoint as a windows workstation.
However if this is not the case then you can create the following condition under the Policy Elements > Conditions > Profiling > New Profiler Condition, you will use the create (advanced...) then select NMAP > 135-tcp > then set the operator EQUAL to msrpc.
Then go under the Microsoft-Workstation and select the option to create a matching identity group (its much easier rather than using the heirarchy option) and set the certainity factor 30. Then add this new condition and set the certainity to 30 also.
Hope that helps,
Tarik Admani
*Please rate helpful posts*
Tarik Admani
James,
Hope that helps,
Tarik Admani
Thanks Tarik,
I'm going to try this on Monday.  FYI, I did test it with DHCP and did see the MSFT class identifier, but i don't have the option to use DHCP as one of the DHCP servers, nor is the helper statement currently used in the current config.  I tried a subset of this, but didn't set the certainty factor to 30.
I'll let you know how it goes.
