Community Member
Removing Base License from ACS5.1
Dear All, Any one knows how to remove base license from ACS5.1 ? By mistake I installed same base license on my both ACS appliance. any way to remove it or I have to reinstall whole ACS ?
Plesae help.
1 ACCEPTED SOLUTION
Gold
Re: Removing Base License from ACS5.1
Are you facing this issue because you want to join two servers in a deployment?
If so can do the following on the server that will be the secondary (not the mastdr of the configuration)
- acs reset-config   /// from CLI to reset configuration to factory default
- login in to server and set acsadmin password and install correct license
- register the server to the deployment. When registration completes the server will get a copy of the master configuration database
1 REPLY
Gold
1572
