02-12-2008 08:37 AM - edited 03-12-2019 05:37 PM
I replaced an ACS certificate that had been installed i then did the following:
1. Created a certificate request.
2. Issued the request to the enterprise CA.
3. Copied the certificate to an ftp server.
4. Installed the certificate on the ACS.
5. Configured the CTL again.
6. Restarted the ACS service.
8. Enable EAP-TLS.
The problem is when i try and enable EAP i get the message no ACS certificate installed.
I searched on cisco and it said to disable the CSA and follow the same process which i have done to no avail.
Any help appreciated.
Kev
Solved! Go to Solution.
02-20-2008 12:09 PM
Yes, the certificate is installed and I have it checked it in the trust list.
-John
02-20-2008 12:14 PM
What is the ext of cert you have installed ?
02-20-2008 12:17 PM
.cer
02-21-2008 03:59 AM
Try Base 64 format.
02-21-2008 05:34 AM
Is RSA key set to 1024 or 2048 ? Use 1024.
~JG
02-21-2008 05:45 PM
02-22-2008 11:17 AM
I forgot to add that RSA 1024 was chosen for the CSR.
Is there any other place to verify that the certificate is installed other then "Install ACS Certificate"?
-John
