Setting up AAA Accounting on 3750 Switches
I'm trying to set up AAA accounting for all commands executed on all of my switches. We have a TACACs Server running Cisco ACS v3.1. What commands do I need to enter on my switches for it to send accounting messages to my TACACs server?
Re: Setting up AAA Accounting on 3750 Switches
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
Hope that helps.
I will give this a try
Also command accounting logs are stored in Tacacs administration report and not in tacacs accounting report.
~JG
Any configuration on ACS ?
After configure this commands, no messages are generated in my ACS, on Tacacs+ Administration ....
Thanks.
If you are running acs 4.1.1 then there is a known issue related to command accounting do not show up.
To fix it you need to apply patch 5 ie 4.1.1 patch 5.
~JG
239
