Is it possible to set up a multi use port that will use dot1x to authenticate several laptops, only 1 connected at a time, but I need the phone to automatically connect without having to make changes to the phone config as I don't have access to the Cisco call manager to set up the authentication.
Setup would be using catalyst 3650x at the access layer, various Cisco ip phones models and a Cisco acs 4.2 server doing the authentication. The laptops would be plugged in through the phone. The switch is already in use and setup and using both data and voice vlans, but now I need to enable it for several users. The acs is already setup to authenticate our wireless network so I'm planning on using the same setup for the wired side.
Have been going through the various guides but not sure on the phone pass through situation, any advice would be great.
Adam
