01-24-2009 01:08 AM - edited 03-10-2019 04:18 PM
I set up a Shell Command Authorization Set. I want to give someone access to enter "configure terminal" and any "mac-address-table static *" commands.
Unmatched commands: Deny
configure -> permit terminal
mac-address-table -> permit static
I built a group and assigned this shell command authorization set to it, level 15, etc.
Now when I create a test user, I can enter "configure terminal" and any other command it seems. "router ospf 21", "interface vlan 101", etc. are all ALLOWED even though I haven't listed them in my command authorization set.
Any idea what I'm missing? Thank you for any responses.
---John Holmes...
01-24-2009 01:26 AM
Just to clarify, the issue seems to be with limiting global configuration commands. I can limit privileged exec commands easily using the Authorization Sets.
Is it not possible to limit global configuration commands once you give the user the ability to enter "configure terminal"?
Thanks.
01-24-2009 09:54 AM
Yes, it is absolutely possible. Like this:
user = test {
member = limited
login = des xxxxxxx
name = "ccie security"
group = limited {
default service = deny
cmd = show {
permit "arp .*"
permit "cam .*"
deny .*
not sure how cisco does it in ACS but in freeware TACACS+, that's how I do it.
01-25-2009 12:43 AM
Thanks for the help. shell command authorization sets don't have a format like that though. I don't know if there's a way to enter permissions like that through ACS.
