Stucked with ACS SE 4.1
I was configuring ACS SE from the console but got stucked in between. Referred the installation guide for the same. After doing the basic configuration when the ACS SE rebooted i was not able to get the login prompt on my console. The ouput which i m getting is pasted below:
Press <SpaceBar> to update BIOS.
[2;37;40mAMIBIOS(C)2006 American Megatrends, Inc.
[06;00H BIOS Date: 11/26/07 15:02:44 Ver: 08.00.14
[07;00H CPU : Intel(R) Pentium(R) 4 CPU 3.40GHz
[08;00H Speed : 3.40 GHz [09;00H
[10;00H Press F2 to run Setup
[11;00H Press F12 for BBS POPUP
[12;00H DDR2 Frequency:667 MHz, ECC Support in Dual-Channel Interleaved Mode
[13;00H Initializing USB Controllers .. Done.
[14;00H 1024MB OK [15;00H
[16;00H Auto-Detecting Pri Master..IDE Hard Disk
[17;00H Auto-Detecting Sec Master..ATAPI CDROM
[18;00H Auto-Detecting Sec Slave...
[19;00H [20;00H [21;00H -[22;00H [23;00H
[18;00H Auto-Detecting Sec Slave...Not Detected
[19;00H Pri Master : Hitachi HDS721680PLA380 P21OABEA
[2;37;40mAuto-detecting USB Mass Storage Devices ..
[23;00H BMC Responding
[06;00H Press F2 to run Setup
-[07;00H Press F12 for BBS POPUP
It gets hanged after this tried many things but no success.
Also one thing which i got to see during installations, there was an option to enable the GUI which i coudnt find in the installation guide. That options was given in installation guide after the device reboots. I had done the configuration for the same during that time as it stated over ther all the services will be enabled if i do enable it. I even tried it accessing through http://ip add : 2002 on the ethernet ports but no success.
Can anyone guide me on the same. Thanks in advance.
3 ACCEPTED SOLUTIONS
Re: Stucked with ACS SE 4.1
This should help, basically you need to change boot seq in BIOS
Please follow the instructions for fixing the BIOS password on ACS appliance 1113.
http://www.cisco.com/en/US/ts/fn/631/fn63111.html
Try 2 reimage it after changing the boot seq.
603
