Swapping master / slave role without losing DB?
I have two ACS 3.1 servers on w2k. One is just a slave and copies the DB from the master. I want to reverse their roles to lighten the load on the ciscoworks server (which is currently the primary acs box as well).
Can I just reconfigure them to sync the other way? Password changes are nonexistant so I'm not worried about missing a recent change, I just don't want to kill my database as recovery isn't something I've done, or care to try just now.
1 REPLY
Re: Swapping master / slave role without losing DB?
Hi Aron,
You could simply disable the replication and that would take away the concept of master/slave or Primary/Secondary.
Later on you could configure the replication which ever way you want between these 2 servers. This will not affect the database.
yatin
126
