TACACS Authentication and Fortigate Appliances
dustin.poole
I have been trying to get TACACS authentication setup for my Fortigate webfilters and analyzers however I am missing the attributes to set the match conditions for the users who log in with the AD credentials to assign them the correct user profile type. I was wondering if anyone has a complete guide on how to do this. Thanks for your help.
26 Replies 26
Eduardo Aliaga
Level 4
Level 4
Hello, in this link you have the fortinet configuration
http://kb.fortinet.com/kb/microsites/microsite.do?cmd=displayKC&externalId=FD33320
If you 're using ACS as your TACACS server then you must configure the following shell profile
Please rate if this helps
I am using ACS as my TACACS server and this post was helpful however I still missing a pieces.I still need the custom attributes to set for each user type like super_admin for example.
It's also not clear to me how or why you have to create user group with no users and noaccess. Thanks for the input.
The link mentions the admin profile called "noaccess" just as an example. You could just use the admin profile called "super_admin"  instead.
Also in the example the user "admin" does belong to the user group "test_group" and this user group is linked to the tacacs server called "tac_plus" .
How do you find out if that the user "admin" belongs to the group "test_group"?
Also, once you configure the Shell Profile, do you need to create a separate Authorization Profile to use that Shell Profile?
I am experiencing issues with this also.  I have my attributes set up same as above example but I get full admin access no matter what I put in the admin_prof value.  When I look in the ACS TACACS logs I see no evidence of any authorization packets being sent to the Fortinet and no value pairs in the authentication reply either.  Any suggestions at all???  We are using V4 M3.
I finally got it to work.
On the Fortinet side, you need to make sure you have an Admin user created (ie, "test") that is setup for Remote login, Wildcard, and a profile of NOACCESS.
On the ACS side, you need to create 2 different Shell Profiles (RW and RO). They should have the following attributes (note, I am referencing the group name from Eduardo's link):
RW
service=fortigate
memberof=test_group
admin_prof=super_admin
RO
service=fortigate
memberof=test_group
admin_prof=read_only
Make sure you have both the super_admin and read_only Admin Profiles on your Fortigate.
Let me know if that helps.
I believe I have it set up as you explained.  I can see in ACS logs that the autho parms are now being sent.
{Type=Authorization; Author-Reply-Status=PassRepl; AVPair=memberof=TacAdmin; AVPair=admin_prof=super_user; AVPair=service=fortigate; }
However, they are not overriding the noaccess setting in the wildcard admin.  I also notice that i can not check the wildcard box in the gui if i try to create a user there.  It is greyed out.  Does the user need to be named "wildcard"? and... does it have to be built in the CLI?
No the user does not need to be named Wildcard. Do you have another user already that has wildcard enabled? I think you can only have Wildcard enabled on 1 user. If you don't have any enabled and it's still greyed out, then try to configure it via the CLI.
config system admin
edit user
set wildcard enable
Post a screenshot of your Admin users.
config system admin
    edit "cbadmin"
        set remote-auth enable
        set accprofile "super_admin"
        set vdom "root"
        set remote-group "RadAdmin"
        set password ENC AK1sRSaM12nMCQq1q3pKtYvepgsbJEDF0AuEWsxFw4eXSE=
    next
    edit "wildcard"
        set accprofile "noaccess"
        set vdom "root"
        set wildcard enable
        set remote-group "TacAdmin"
        set accprofile-override enable
    next
    edit "admin"
        set vdom "root"
        set password ENC AK167u4bh2JDbsjRKqG7q4zjkbL6cQOUCN7gKwqFDBMf9A=
    next
    edit "jdickler23"
        set accprofile "prof_admin"
        set vdom "root"
        set password ENC AK17gik2+xKWlkgiSK8IUpLpE+0zI5veH5vplRvI+B0RMc=
    next
    edit "jdicklertest"
        set vdom "root"
        set password ENC AK1twU3/13H7u/D1vdjMXvOJqP3UmEtWwdG4JQDfofgnuM=
    next
    edit "pkgeev01"
        set vdom "root"
            set password ENC AK1kOd5dSxmKm8A47m0D05OITNrozFsiaCGk4lyOv3ugaQ=
    next
end
we got it to work..... mixed up super_admin with the more popular super_user.  once corrected it all works fine.  thx for your input it was very reassuring.
Mine is working with multiple VDOMs. Also, I make local admin as a last resort login, so user have to login with their AD credential, unless ACS has problem or unreachable, then users can login with admin.
Hi All,
I am attempting to set up authentication from Fortigate V5 towards ACS v4.2.
I am trying to setup the attributes for noaccess and have run into an issue of:
config system accprofile
   edit "noaccess"
      unset menu-file
   next
end
I cannot do the command unset menu-file. The only options I have with unset are:
admingrp                Access permission.
authgrp                 Access permission.
comments                Comments.
endpoint-control-grp    Access permission.
fwgrp                   Access permission.
loggrp                  Access permission.
mntgrp                  Access permission.
netgrp                  Access permission.
routegrp                Access permission.
scope                   Global or single VDOM access restriction.
sysgrp                  Access permission.
updategrp               Access permission.
utmgrp                  Access permission.
vpngrp                  Access permission.
wanoptgrp               Access permission.
wifi                    Wireless controller.
Thanks.
Jack.
Try the following (also, it's easier to create this in the GUI as there is only 1 button to set everything to unset):
edit "noaccess"
        set admingrp none
        set authgrp none
        set endpoint-control-grp none
        set fwgrp none
        set loggrp none
        unset menu-file
        set mntgrp none
        set netgrp none
        unset roles
        set routegrp none
        set scope vdom
        set sysgrp none
        set updategrp none
        set utmgrp none
        set vpngrp none
        set wanoptgrp none
        set wifi none
    next
end
Thanks for the prompt response.
I am now encountering problems setting the av pairs.
Below is my configuration:
Any assistance would be appreciated.
Thanks.
Jack.
