Tacacs+ Enable password is not working on Cisco Switch
Ladies/Gents,
I am facing issues when enabling tacacs authentication on my cisco switch, aaa login/password is working, aaa enable is not. Underneath details of my devices.
Cisco ACS 1121: version 5.1
Cisco Switch 3560: ios ver 15
I also attached here some documents for your review and comment (switch aaa configuration, debug aaa authentication, acs captured screen)
Hoping to receive an update and comment from you soon.
Arnold
7 Replies 7
edwjames
Level 3
Level 3
The problem lies in the shell profile being assigned in the authorization section of the ACS configuration.
Access Policies--> Default device admin (or a one you have created)--> Authorization--> look at the rule that matches.
The shell profile has to have maximum privilege set to 15 for this to work.
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
Hi Edward,
I created a new shell profiles named "root" as the default one "Permit Access" can't be access or modified, underneath the steps I've made.
1. Create a new shell profile name "root" with max privilege of 15. And then used it in "Default Device Admin/Authorization/Rule-1" shell profile - see attached file for more details.
2. Telnet the Switch and then Issue "debug aaa authentication" using both "Root Shell" and "Permit Access" applied in Rule-1 profile.
Note:
I also attached here the captured screen and debug result for the "shell profiles"
Further there's also some discussion, seems related to this issue, but its using ACS version 4.2
https://learningnetwork.cisco.com/thread/35151?start=0&tstart=0
Are you still facing issue with the enable password authentication?
Jatin
** Do rate helpful posts**
~Jatin
Arnold,
Did you edit the service selection rules?
Labminutes has some really good videos for configuring ACS. It will walk you through exactly what you're trying to do.
http://labminutes.com/video/sec/ACS
Naveen Kumar
Level 4
Level 4
please have a look on this docunment for Steps to configure Tacacs Authentication
https://supportforums.cisco.com/docs/DOC-8572
blenka
Level 3
Level 3
