04-07-2006 07:01 AM - edited 03-10-2019 02:32 PM
I have a ACS 3.2 and a router 2811 tried to authenticated it. When i put a debug tacacs the router displays "write to 192.168.241.200 failed with errno 257((ENOTCONN))" the connectivity is ok but the request doesn´t arrive to acs, the other devices work ok, with the same configuration. I need to know if there are a solution for this issue.
thanks for your help,
04-12-2006 11:05 AM
The issue here is related to a bug CSCin76722.
04-16-2007 06:27 AM
do we have any additional information for a solution? anyone ?
I have the same issue (ENOTCONN error) on 2811 running 12.4.4-12.4.13a ip-base IOS.
Connectivity, tacacs key and ACS(3.3) double checked already.
Thanks.
06-19-2011 12:15 AM
I had a same error and due to some misconfiguration it was starting blocked on the firewall. Have to allow port 49 towards ACS server and it started working.
Cherrs.,
07-12-2014 10:42 AM
I had a similar symptom on my lab too, using a free TACACS+ server. I confirm that it's probably a firewall issue as it has been said. Disable the firewall for a while and see what happens.
