TACACS+ is not working on PIX Firewall
chaitu_kranthi
Recently we installed the Cisco ACS 4.2 ver in our network and we are adding the network devices to it. now all the network devices are working with TACACS+ id's except the secuirty device like pix firewalls
existing pix configuration...
Cisco PIX Firewall Version 6.3(4)
Cisco PIX Device Manager Version 3.0(2)
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server TACACS+ (inside) host x.x.x.x test timeout 10
some one pls help me in this.
Did you enable it for telnet / ssh/http access authentication ?
aaa authentication telnet console TACACS+
aaa authentication ssh console TACACS+
Here are the commands to need,
PIX ( CODE 6.3.4 )
username Test password cisco
username Test privilege 15
aaa-server TACACS protocol tacacs+
aaa-server TACACS (outside) host 10.130.102.191 cisco timeout 10
aaa authentication http console TACACS LOCAL
aaa authentication ssh console TACACS LOCAL
aaa authentication telnet console TACACS LOCAL
aaa authentication enable console TACACS LOCAL
If you don't need SSH,HTTP then no need to use it.
~JG
Do rate helpful posts
