unable to logout of shell
Good day to all. I have a couple of ACS 5.4 appliances that we have command sets working in almost to point where we are finished.
Below is the AAA config we are using.
When I put the command set authorized commands for the shell they all work except "exit" and "end"
When logged in as a user of the particular AD group you an do work but you can never exit properly.
You have to kill the shell window, SSH V2 in our case, to get out.
aaa new-model
aaa authentication login default group tacacs+ enable line
aaa authentication login VTY group tacacs+
aaa authentication login CONSOLE group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication dot1x default group radius
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization exec CONSOLE group tacacs+ local
aaa authorization exec VTY group tacacs+
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 1 VTY group tacacs+
aaa authorization commands 15 default group tacacs+ local
aaa authorization commands 15 VTY group tacacs+
aaa authorization network default group radius
aaa authorization network auth-list group radius
aaa authorization auth-proxy default group radius
aaa accounting update periodic 1
aaa accounting auth-proxy default start-stop group radius
aaa accounting dot1x default start-stop group radius
aaa accounting exec CONSOLE start-stop group tacacs+
aaa accounting commands 1 VTY start-stop group tacacs+
aaa accounting commands 15 VTY start-stop group tacacs+
aaa session-id common
our Command sets in V5.4 look like this:
Grant                    Command               Arguments
Permit                    end
Permit                    exit
Permit                    enable
Permit                    show                    int* f*
Permit                    show                    int* g*
Permit                    show                    port-security
Permit                    show                    int* status
Permit                    clear                    port-security sticky int* g*
Permit                    clear                    port-security sticky int* f*
Permit                    ping
ej
164
