Upgrade ACS 4.0 to 4.1.1.24 doesn't work
I try to upgrade to 4.2 on Windows Server 2003SP1. First step was to apply the CSCsh32888 Patch (replace an exe), which is OK.
next step is the upgrade to 4.1.1.24. I Installed IIS6, checked the JRE-Versions, Stopped all services including MCAfee, RDP and Monitoring. I restarted the machine more than one.
Problem:
I start the setup.exe from 4.1.1.24, for about 2 seconds the hourglass next to the mousepointer appears, then hourglass disappears and nothing more happens.
The setup.exe-process still is in the processlist (taskmanager) but nothing else.
Any hints?
I activated the 2nd NIC (as mentioned in the upgrade guide, I stopped all services, that probably can access the ACS files, tried to follow all guides from cisco.
*confused*
Thanks in advance
Re: Upgrade ACS 4.0 to 4.1.1.24 doesn't work
I solve this problem by myself.
Just disableing and kill "all" programs that are not neccesary to run basic windows, eg. hp simtools ...
Hi, do you remember from were
Hi, do you remember from were you got the CSCsh32888 path?
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
286
