Community Member
upgrade ACS 4.0 to 4.1
I wan upgrade ACS 4.0 to 4.1 on ACS SE, i have read document but i don't have ACS SE 4.1 Upgrade CD, please guide obtain ACS SE 4.1 Upgrade CD
thanks
ducnv
Re: upgrade ACS 4.0 to 4.1
Download it from CCO. If you want the actual CD, you'll have to open a TAC case.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
Community Member
Thanks ccbootcamp, I have found with CCO, but i didn't find it. If you have download, can give link
Thanks very much
Community Member
Hi ducnv
As far as I am aware this is not available for download You can only obtain the upgrade package for ACS by contacting TAC. You would not be able to download the software package on CCO.
You can only download minor patches from the CCO.
Regards MJ
Community Member
Thanks for your replies
I have just order a ACS Appliance 4.1, and i have a old ACS Appliance 4.0, i want repplicate two device but i have not upgraded ACS Appliance 4.0 to 4.1. have you done???? can i order ACS Upgrade CD????
Ducnv
thanks
211
