Users authorized commands
rrcarter79
I want to restrict some users to "show running-config" command.
I have created a Shell Command Authorization Set with "show" command "permit running-config". Under the TACACS+ setting the Shell (exec) is selected and Privilege level with a value of 5. The SCAS is associated to the username.
Config on a Router:
aaa new-model
aaa authentication login vty group tacacs+ local
aaa authentication login console line
aaa authentication enable default group tacacs+ enable
aaa authorization exec vty group tacacs+ local
aaa authorization commands 5 vty group tacacs+
line vty 0 4
exec-timeout 30 0
password ***Deleted****
login authentication vty
The user gets the privilege of 5 when logged in but is unable to execute the command show running-config.
21 Replies 21
4brown
sh run is a priv lvl 15 command by default. You can change it to level 5 with the:
privilege exec level 5 show running-config
command.
Yes that does work, but I would rather set this up using the Shell Command Authorization Set with the ACS server.
There are many more commands to include for different users and configuring every router and switch with each command required is a very large task.
How is this done with Shell Command Authorization Sets?
Do you have:
on the line vty ports? Wasn't specified in your earlier post.
Sorry - yes it is.
Try quoting "running-config"
If that doesn't work, try just permitting "run".
Pasting debug aaa authorization and debug tacacs+ may help identify the issue.
Using quotes does not work. The parameters inclosed in quotes disappears.
So I tried just permit run.
I logged in with username "username".
I gain access and get a priv of 5 and a # sign prompt.
Issue a sho run and receive an error.
------ Login Session ----------
Username: username
Password:
LabrtrB#sho priv
Current privilege level is 5
LabrtrB#
LabrtrB#sho run
% Invalid input detected at '^' marker.
LabrtrB#
Here are the debugs:
LabrtrB#debug aaa authorization
AAA Authorization debugging is on
LabrtrB#
Jan 15 22:11:52.728: tty2 AAA/AUTHOR/EXEC (3878016830): Port='tty2' list='vty' service=EXEC
Jan 15 22:11:52.728: AAA/AUTHOR/EXEC: tty2 (3878016830) user='username'
Jan 15 22:11:52.728: tty2 AAA/AUTHOR/EXEC (3878016830): send AV service=shell
Jan 15 22:11:52.728: tty2 AAA/AUTHOR/EXEC (3878016830): send AV cmd*
Jan 15 22:11:52.728: tty2 AAA/AUTHOR/EXEC (3878016830): found list "vty"
Jan 15 22:11:52.728: tty2 AAA/AUTHOR/EXEC (3878016830): Method=tacacs+ (tacacs+)
Jan 15 22:11:52.728: AAA/AUTHOR/TAC+: (3878016830): user=username
Jan 15 22:11:52.728: AAA/AUTHOR/TAC+: (3878016830): send AV service=shell
Jan 15 22:11:52.728: AAA/AUTHOR/TAC+: (3878016830): send AV cmd*
Jan 15 22:11:52.932: AAA/AUTHOR (3878016830): Post authorization status = PASS_ADD
Jan 15 22:11:52.932: AAA/AUTHOR/EXEC: Processing AV service=shell
Jan 15 22:11:52.932: AAA/AUTHOR/EXEC: Processing AV cmd*
Jan 15 22:11:52.932: AAA/AUTHOR/EXEC: Processing AV priv-lvl=5
Jan 15 22:11:52.932: AAA/AUTHOR/EXEC: Authorization successful
Jan 15 22:12:49.963: AAA/MEMORY: free_user (0x629A26BC) user='username' ruser=''
port='tty2' rem_addr='x.x.x.x' authen_type=ASCII service=LOGIN priv=1
LabrtrB#debug tacacs
TACACS access control debugging is on
LabrtrB#
Jan 15 22:13:50.599: TAC+: send AUTHEN/START packet ver=192 id=1365478173
Jan 15 22:13:50.599: TAC+: Using default tacacs server-group "tacacs+" list.
Jan 15 22:13:50.599: TAC+: Opening TCP/IP to x.x.x.x/49 timeout=5
Jan 15 22:13:50.599: TAC+: Opened TCP/IP handle 0x62A8E470 to x.x.x.x/49
Jan 15 22:13:50.599: TAC+: x.x.x.x (1365478173) AUTHEN/START/LOGIN/ASCII queued
Jan 15 22:13:50.799: TAC+: (1365478173) AUTHEN/START/LOGIN/ASCII processed
Jan 15 22:13:50.799: TAC+: ver=192 id=1365478173 received AUTHEN status = GETUSER
Jan 15 22:13:53.499: TAC+: send AUTHEN/CONT packet id=1365478173
Jan 15 22:13:53.503: TAC+: x.x.x.x (1365478173) AUTHEN/CONT queued
Jan 15 22:13:53.703: TAC+: (1365478173) AUTHEN/CONT processed
Jan 15 22:13:53.703: TAC+: ver=192 id=1365478173 received AUTHEN status = GETPASS
Jan 15 22:13:55.435: TAC+: send AUTHEN/CONT packet id=1365478173
Jan 15 22:13:55.435: TAC+: x.x.x.x (1365478173) AUTHEN/CONT queued
Jan 15 22:13:55.635: TAC+: (1365478173) AUTHEN/CONT processed
Jan 15 22:13:55.635: TAC+: ver=192 id=1365478173 received AUTHEN status = PASS
Jan 15 22:13:55.635: TAC+: Closing TCP/IP 0x62A8E470 connection to x.x.x.x/49
Jan 15 22:13:55.635: TAC+: using previously set server x.x.x.x from group tacacs+
Jan 15 22:13:55.635: TAC+: Opening TCP/IP to x.x.x.x/49 timeout=5
Jan 15 22:13:55.639: TAC+: Opened TCP/IP handle 0x62A8E8FC to x.x.x.x/49
Jan 15 22:13:55.639: TAC+: Opened x.x.x.x index=1
Jan 15 22:13:55.639: TAC+: x.x.x.x (305665778) AUTHOR/START queued
Jan 15 22:13:55.839: TAC+: (305665778) AUTHOR/START processed
Jan 15 22:13:55.839: TAC+: (305665778): received author response status = PASS_ADD
Jan 15 22:13:55.839: TAC+: Closing TCP/IP 0x62A8E8FC connection to x.x.x.x/49
Jan 15 22:13:55.839: TAC+: Received Attribute "priv-lvl=5"
The IOS doesn't recognize the command because you are coming in at Privilege Level 5. If you don't want to use the Privilege Exec command, try this. Assign this group Privilege Level 15, and enforce authorization for priv 15:
aaa authorization commands 15 vty tacacs+
line vty 0 4
Then, for this group, deny all the commands you want. sh run will be permitted since they are priv 15, but the commands you deny in the ACS will be denied.
Actually I assigned the priv level 15 to the user.
router config:
aaa authorization commands 15 vty group tacacs+
line vty 0 4
exec-timeout 30 0
password 7 082C5F4B05180719171F
Then for the user I allow the command sho running-config. Since this is the only priv level 15 command the user can run, it shows the configuration.
So the commands don't have to be assigned to a different level. This process assigns the onyl commands the user can execute.
Understanding this now lets me customize the commands any user can execute. This is what I was wanting to do.
Thanks for the help! I have a much better understanding now.
I spoke too soon.
I am not able to control the configuration commands.
For example letting a user only change description on a line.
Command authorization for config mode commands needs to be permitted:
aaa authorization config-commands
If this is not enabled, once in config mode, no requests are sent to the AAA server.
I've added aaa authorization config-commands to no avail.
I assume it will authorize config-commands against the command authorization set.
The only config-command that I have in the command authorization set is "location"
Post debug aaa author showing it fail...
Here is the login session and debug. I have allowed "config" with "permit term" and "location".
I don't want the user to access the interfaces or lines.
Login:
Unauthorized access is strictly prohibited!
User Access Verification
Username: username
Password:
LabrtrB#config t
Enter configuration commands, one per line. End with CNTL/Z.
LabrtrB(config)#line vty 0 4
LabrtrB(config-line)#ex
% Ambiguous command: "ex"
LabrtrB(config-line)#exit
LabrtrB(config)#
LabrtrB(config)#
LabrtrB(config)#end
LabrtrB#
Debug:
LabrtrB#
Jan 21 11:51:02.300: AAA: parse name=tty3 idb type=-1 tty=-1
Jan 21 11:51:02.300: AAA: name=tty3 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=3 channel=0
Jan 21 11:51:02.300: AAA/MEMORY: create_user (0x629B4624) user='' ruser='' port='tty3' rem_addr='16.47.225.189' authen_type=ASCII service=LOGIN priv=1
Jan 21 11:51:11.960: tty3 AAA/AUTHOR/EXEC (559394384): Port='tty3' list='vty' service=EXEC
Jan 21 11:51:11.960: AAA/AUTHOR/EXEC: tty3 (559394384) user='username'
Jan 21 11:51:11.960: tty3 AAA/AUTHOR/EXEC (559394384): send AV service=shell
Jan 21 11:51:11.960: tty3 AAA/AUTHOR/EXEC (559394384): send AV cmd*
Jan 21 11:51:11.960: tty3 AAA/AUTHOR/EXEC (559394384): found list "vty"
Jan 21 11:51:11.960: tty3 AAA/AUTHOR/EXEC (559394384): Method=tacacs+ (tacacs+)
Jan 21 11:51:11.960: AAA/AUTHOR/TAC+: (559394384): user=username
Jan 21 11:51:11.960: AAA/AUTHOR/TAC+: (559394384): send AV service=shell
Jan 21 11:51:11.960: AAA/AUTHOR/TAC+: (559394384): send AV cmd*
Jan 21 11:51:12.164: AAA/AUTHOR (559394384): Post authorization status = PASS_ADD
Jan 21 11:51:12.164: AAA/AUTHOR/EXEC: Processing AV service=shell
Jan 21 11:51:12.164: AAA/AUTHOR/EXEC: Processing AV cmd*
Jan 21 11:51:12.164: AAA/AUTHOR/EXEC: Processing AV priv-lvl=15
Jan 21 11:51:12.164: AAA/AUTHOR/EXEC: Authorization successful
Jan 21 11:51:15.188: tty3 AAA/AUTHOR/CMD (3225337257): Port='tty3' list='vty' service=CMD
Jan 21 11:51:15.188: AAA/AUTHOR/CMD: tty3 (3225337257) user='username'
Jan 21 11:51:15.192: tty3 AAA/AUTHOR/CMD (3225337257): send AV service=shell
Jan 21 11:51:15.192: tty3 AAA/AUTHOR/CMD (3225337257): send AV cmd=configure
Jan 21 11:51:15.192: tty3 AAA/AUTHOR/CMD (3225337257): send AV cmd-arg=terminal
Jan 21 11:51:15.192: tty3 AAA/AUTHOR/CMD (3225337257): found list "vty"
Jan 21 11:51:15.192: tty3 AAA/AUTHOR/CMD (3225337257): Method=tacacs+ (tacacs+)
Jan 21 11:51:15.192: AAA/AUTHOR/TAC+: (3225337257): user=username
Jan 21 11:51:15.192: AAA/AUTHOR/TAC+: (3225337257): send AV service=shell
Jan 21 11:51:15.192: AAA/AUTHOR/TAC+: (3225337257): send AV cmd=configure
Jan 21 11:51:15.192: AAA/AUTHOR/TAC+: (3225337257): send AV cmd-arg=terminal
Jan 21 11:51:15.392: AAA/AUTHOR (3225337257): Post authorization status = PASS_ADD
Jan 21 11:51:20.420: AAA/AUTHOR: config command authorization not enabled
Jan 21 11:51:26.816: AAA/AUTHOR: config command authorization not enabled
Jan 21 11:51:32.408: AAA/AUTHOR: config command authorization not enabled
Jan 21 11:51:32.408: %SYS-5-CONFIG_I: Configured from console by username on vty1 (16.47.225.189)
Jan 21 11:51:42.128: %SYS-4-SNMP_WRITENET: SNMP WriteNet request. Writing current configuration to 16.22.4.5un all
Jan 21 11:51:48.048: tty2 AAA/AUTHOR/CMD (1731012520): Port='tty2' list='vty' service=CMD
Jan 21 11:51:48.048: AAA/AUTHOR/CMD: tty2 (1731012520) user='admin'
Jan 21 11:51:48.048: tty2 AAA/AUTHOR/CMD (1731012520): send AV service=shell
Jan 21 11:51:48.048: tty2 AAA/AUTHOR/CMD (1731012520): send AV cmd=undebug
Jan 21 11:51:48.048: tty2 AAA/AUTHOR/CMD (1731012520): send AV cmd-arg=all
Jan 21 11:51:48.048: tty2 AAA/AUTHOR/CMD (1731012520): found list "vty"
Jan 21 11:51:48.048: tty2 AAA/AUTHOR/CMD (1731012520): Method=tacacs+ (tacacs+)
Jan 21 11:51:48.048: AAA/AUTHOR/TAC+: (1731012520): user=admin
All possible debugging has been turned off
LabrtrB#
Jan 21 11:51:48.048: AAA/AUTHOR/TAC+: (1731012520): send AV service=shell
Jan 21 11:51:48.048: AAA/AUTHOR/TAC+: (1731012520): send AV cmd=undebug
Jan 21 11:51:48.048: AAA/AUTHOR/TAC+: (1731012520): send AV cmd-arg=all
Jan 21 11:51:48.252: AAA/AUTHOR (1731012520): Post authorization status = PASS_ADD
You need to have config-command authorization as specified in the previous post so it sends commands in config mode to the aaa server for approval. Note in your post, config command authorization is not configured.
Once it is, it will send each command in config mode to be permitted or denied to the AAA server. So if you want to deny access to line or interfaces, then specify these commands denied in the server.
When you enable it, look at your debug aaa authorization, you should see if the command is allowed or denied in the authorization status. That tells you if you have configuration issues in the AAA server.
