01-29-2007 11:29 AM - edited 03-10-2019 02:57 PM
Is it possible to direct aaa authentication/authorization for my "auth-proxy" function to one TACACS server and send all other authentication/authorization requests to a different TACACS+ server?
Solved! Go to Solution.
01-30-2007 07:35 AM
Turn the problem upside down...
I bet your using tacacs+ default method for vty(telnet or ssh) access to the router. You can specify an aaa method for the vty,con and aux line interface on your router. Use the default for your auth-proxy and a named mothod for the administration.
01-29-2007 12:35 PM
Yes
You must first define each server.
After Create 2 server group
aaa group server tacacs tac1
server x.x.x.x (server1)
aaa group server tacacs tac2
server x.x.x.x (server2)
Then use those server group in your aaa method list insted of the keyword Tacacs.
01-30-2007 02:06 AM
Hi dominic,
Thnx for responding. I was already testing with AAA server groups, however I can't seem to get it right. I've tried the folowing:
aaa group server tacacs+ proxy-test
server 212.84.0.19
aaa authentication login default group tacacs+ local
aaa authentication login auth-proxy group proxy-test
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default if-needed group tacacs+ none
aaa authorization exec default group tacacs+ local
aaa authorization network default group tacacs+ local
aaa authorization auth-proxy default group proxy-test
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
ip auth-proxy inactivity-timer 10
ip auth-proxy name proxy-test http
Interface X
ip auth-proxy proxy-test
tacacs-server host x.x.x.x key x
tacacs-server host y.y.y.y key y
It seems the authentication/authorization for is always directed at the "default" list of methods. Auth-proxy on the same tacacs server is no problem and works fine.
01-30-2007 07:35 AM
01-30-2007 07:51 AM
Hi dominic,
:) As you can see, I've just come to the same conclusion.
It is possible to use a named method list for the auth-proxy? If it's not i'll leave it with this setup.
Thnx many times
01-30-2007 07:47 AM
Okay, after some testing i have an initial and working setup:
server x.x.x.x
aaa authentication login default group proxy
aaa authentication login maintenance group tacacs+ local
aaa authentication ppp maintenance if-needed group tacacs+ none
aaa authorization exec maintenance group tacacs+ local
aaa authorization network maintenance group tacacs+ local
aaa accounting exec maintenance start-stop group tacacs+
aaa accounting commands 0 maintenance start-stop group tacacs+
aaa accounting commands 15 maintenance start-stop group tacacs+
aaa accounting network maintenance start-stop group tacacs+
aaa accounting connection maintenance start-stop group tacacs+
Interface X
line 0 15
login authentication maintenance
line con 0
What i saw in the AAA debugs during an auth-proxy requestis that the "AAA authentication default" method list is always requested. I want to be able to create a named method list for this feature, but i'm not sure if i'll get it working. For now this will do.
01-30-2007 08:01 AM
I think auth-proxy is tied to the http server implementation. This is a guess but you could try to change the http server aaa method...
ip http authentication aaa login-authentication (method)
Sorry, cant test this on my prod network :(
01-31-2007 02:10 AM
Dominic,
When I specify a named method for example: "ip http authentication aaa login-authentication test" the auth-proxy function still requests the default method list.
So if i'm going to implement this feature it seems i'll have to leave the default method list for auth-proxy functions.....
01-30-2007 02:39 AM
double post
01-30-2007 06:16 AM
How can I configure a secondry ACS server on Pix ?
01-30-2007 07:48 AM
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ host 1.1.1.1
aaa-server TACACS+ host 2.2.2.2
This is usualy simple. If you need to load-balance on the two server, you need a CSS or something like that. Tacacs is generaly easy to loadbalance, radius is another story(udp). Since UDP is not connection oriented, you must rely on connection timeout.
