Using NEAT in 802.1x
Ahmad Samir
Dear all
I have a switch and I need to do a supplicant auhentication.
I tried the same NEAT config. which is in the document but in the ACS I got a failed attempts and the reason is EAP type not configured.
Switchs 3560
ACS 4.1(1) Build 23 Patch 5
Any help
Ahmad Samir
Dear All
Any help, please.
did you add device-traffic-class=switch to cisco-av-pairs on ACS?  Also, i had to change the native vlan on the supplicant switch side (acs adds this to the port config).
I cant seem to get hosts on supplicant switch to do dot1x for some reason though?
