virtual telnet and acs problem
Have downloaded a document from the cisco website that explains
that you can configure a group on a CSACS server to reference
a named access-list configured on a AAA client i have configured
the group (see attachment) and placed a user in it (user1)
What i am trying to acheive is this i want user1 to be only able
to access a shared folder on a file server located on a server
with the ip address of 192.168.2.3 that is located on the outside
nterface of a pix 515 firewall and not any shared folders on any
other machine located on the outside interface nor do i want him
to have access to the internet
(user1's machine is located on the inside interface)
i have created this access-list on the firewall
access-list sales permit ip any host 192.168.2.3
access-list sales deny ip any any
Being the resource i am trying to connect to is not one you can
authenticate against ie http telnet or ftp i have to authenticate
via virtual telnet.
i have enabled virtual telnet on the pix
virtual telnet 192.168.2.21
the problem i have is that when i try to authenticate via virtual
telnet the authentication fails with the following message
Error: acl authorisation denied
I assume that something has to be added to the access-list
but i not sure what
I have been right through the downloaded document but there is no mention
of any further configuraion that needs to be done
when i set the same network up without the group referencing any named
acls there is no authentication problems
Has anybody any ideas as to what has to be done to get this to work
Melvyn Brown
134
