Vmware requirements for ACS 4.1.4
ebarba123
What are the VMware requirements to run ACS4.1.4?  Im trying to use a VM this as the migration server.  According to the cisco docs, it states that:
"ACS 4.1 has been tested on the VMWare ESX server with the following configuration:
VMWare ESX Server 3.0.0
16 GB of RAM
AMD Opteron Dual Core processor
300 GB hard drive
Four virtual machines
Windows 2003 Standard Edition
3 GB of RAM for the guest operating system"
I understand it will work as it "has been tested" with those specs, but the doc does not state the minimum requirements for the virtual machine.  I dont want to use/find 300GB of space if I only need 20GB(as an example) to make it work.
Jagdeep Gambhir
Level 10
Level 10
The actual amount of hard drive space required  depends on several factors, including log file growth, and replication  or backup purposes. This is something we have not tested on vm
In non vm environment we need atleast 1 GB of free hard drive space minimum.
My guess 20 GB should be sufficient.
~JG
Do rate helpful posts!
20 GB of hard disk space on a VM will not work. Our ACS 4.2.1 crashed yesterday due to a lack of hard disk space. We had 20 GB of hard disk space configured and there was no free disk space, as a result the system stopped working.
