11-06-2013 12:58 PM - edited 03-10-2019 09:04 PM
Hello All
Can anyone assist? I have converted our APs to WDS. The original configs had a username and privilege 15 password and a higher level enable secret. Before the changes when telneting in I obtained the elevated # prompt to config . After the WDS config where I applied aaa-new model, when I remote in I have to type in the secret password to gain # access. I understand the Radius config is the cause but not sure how to get back to a single sign on to the # prompt.
Can anyone able to advise?
AP1_WDSHost#sh run
Building configuration...
Current configuration : 2864 bytes
! Last configuration change at 00:13:17 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname AP1_WDSHost
logging rate-limit console 9
enable secret 5 $1$3rSL$AqddK0YdVjiZpbgRL0JSAvz/
aaa new-model
aaa group server radius rad_eap
server 192.168.100.51 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius Infrastructure
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login method_Infrastructure group Infrastructure
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip cef
dot11 syslog
dot11 ssid Colgrims
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 1234567890
username Cisco password 7 02250D480809
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm tkip
ssid Colgrims
antenna gain 0
station-role root
world-mode dot11d country-code GB indoor
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface GigabitEthernet0
no ip address
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.100.51 255.255.255.0
ip default-gateway 192.168.100.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
no authentication eapfast
no authentication mac
nas 192.168.100.51 key 7 120D041A025B1C54
user infra nthash 7 135035465C5C257F0E017D6A1676455730515cccdsssa595741320D000F7106
user infra2 nthash 7 135035465C5C257F0E017D6A1676455730515cccdsssa595741320D000F7106
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.100.51 auth-port 1812 acct-port 1813 key 7 1311161F1B5C147A
radius-server vsa send accounting
bridge 1 route ip
wlccp ap username infra password 7 111D180807421B5C
wlccp authentication-server infrastructure method_Infrastructure
wlccp wds priority 254 interface BVI1
line con 0
line vty 0 4
transport input all
end
AP1_WDSHost#$
AP1_WDSHost#
Dave
11-14-2013 05:06 AM
I found that the issue was only witht the WDS clients and not the master. I added the following to the client config and this removed the need to enter the Enable Secret password for Priv access
Hope this helps someone
11-17-2013 07:12 AM
This device will act as a WDS client AP.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080c1e2aa.shtml
