When WLC will dACL from ISE
Hi all !
We are used ISE for aaa our users, but our problems is not simple configuration ACL for users access on WLC,
When Cisco make support dACL on WLC (not airspaceACL), it's very important.
Because using GUI WCL for create ACL with limit 64 entry, you think it's normal?
We are do not use VLAN assignment, because it's not work correctly in PEAP MS Windows DomainMachine or User authen, and after DomainMachine auth, User auth not vlan assignment, and user should reconnect to WLAN for correct VLAN  assignment.
Everyone's tags (1)
I don't even think this is on
I don't even think this is on the works. I asked during Cisco live and I was told that it is not on the road-map. :(
Thank you for rating helpful posts!
To further expand, I think
To further expand, I think Cisco and the industry is heading towards SGT/SGA so dACLs are going to be the "old-way" of doing things.
259
