where are octet and packet defined
mayhem2022
I use Cisco ACS for Radius AAA to remote access users. The radius accounting logs have the columns Acct-Input-Octets, Acct-Output-Octets, Acct-Input-Packets, and Acct-Output-Packet. I found documentation explaining these fields but nothing on the value of an octet or packet. For example, If I have the value 900 under Acct-Input-Octets, where 8 bits or 8 bytes received from the remote client? Also, if there were 1,000 packets received what is the size of one packet?
5 Replies 5
sirpa_k
Any update on this ?
sanpatel
An octet is 8 bits.
RFC2866 explains these RADIUS attributes.
A Byte has 8 bits but an actet has only 4 bits!!!
Details on IP Frameformat:
http://www.zytrax.com/tech/protocols/tcp.html
I don't understand how you came to that conclusion. Read any of the RADIUS RFCs. The RFCs even have diagrams of the RADIUS packet and attribute formats. They even number each bit in the octet, e.g
0 1 2
0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
| Type | Length | Value ...
Type
The Type field is one octet.
or just google it.
HI sanpatel,
sorry for the confusion everyone! You are right, of course. Seems to be that I had a temporary blackout ;-)
