Showing results forĀ
Search instead forĀ
Did you mean:Ā
whether cisco WS-C2950G-12 switch supports MAb configuration
kanchand
Hi All,
My Switch is c2950 and i am trying for a MAb Authentication using ACS  .Please let me know will this switch supports and if not is there any way how to use this switch for MAb authentication.
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA1b.bin
cisco WS-C2950G-12-EI (RC32300) processor (revision L0) with 2.
Please let em know the commands that needs to be configured for MAB authentication.
Tiago Antunes
WS-C2950G-12 switch does not support MAB.
Below you will find a generic deployment guide fo MAB:
http://preview.cisco.com/en/US/docs/solutions/Enterprise/Campus/IBD/MACAuthB.html.
The basic commands for MAB are:
interface FastEthernet0/1
 switchport access vlan 2
 switchport mode access
 dot1x mac-auth-bypass
 dot1x pae authenticator
 dot1x port-control auto
 spanning-tree portfast
 spanning-tree bpduguard enable
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Tiago Antunes
HTH,
Tiago
