Which Switches support wired LEAP?
Does any Cisco switch that has AAA support LEAP (like my old 2950)? If not, what's the the least expensive switch that will support wired LEAP?
Thanks!
-Phil
Thanks!
Re: Which Switches support wired LEAP?
2950s support 802.1X.
So is that a yes or a no? I'm not quite certain of the relationship between .1X and LEAP. Is LEAP just like any other of the EAPs, or does the authenticator need to know specifically about LEAP?
LEAP should be like any other EAP type. The authenticator need not know about it unless it's an EAP-server.
And most of the time, switches are pass thru's for EAP, so don't know the difference b/t LEAP and TLS really.
Hi Phi,
LEAP works with wireless. Cisco LEAP supports several Cisco wireless products, including Cisco Aironet autonomous and lightweight access points, Cisco wireless LAN controllers, workgroup bridges, wireless bridges, and repeaters, and many Cisco and Cisco Compatible WLAN client devices.
On switch you can use Dot1x authentication.
~JG
Yes, I can successfully use LEAP for wireless authentication. Does this mean LEAP will NOT work for wired authentication on a Cisco Catalyst switch?
LEAP should work fine on a wired switch.
As per my understanding LEAP requires WAP and does not work on wired networks.
Do you mean "WPA"? WPA Enterprise includes EAP. Most Cisco switches support EAP. Why wouldn't it work?
jafrazie & jgambhir seem to totally dissagree.
Search for "LEAP" in the following document. It seems to imply that's it possible but nothing conclusive.
http://www.cisco.com/application/pdf/en/us/guest/products/ps5528/c1161/cdccont_0900aecd8035eb89.pdf
-Phil
Phil,
It seems that if you have any wired supplicant supporting LEAP, it is going to work.
But I don't think we have any wired supplicant supporting LEAP ?
~JG
191
