01-10-2012 12:54 AM - edited 03-10-2019 06:42 PM
Hi all,
Having issue with WLC 5508 using ACS 5.2 tacacs+ protocol to do device management
The problem statement is after key in the username and password on the WLC login page, it is endlessly prompt for authentication on WLC.
Whilst on ACS monitoring and reporting i able to see it is successfully authenticated, shown at AAA protocol > TACACS+ Authentication
On ACS, the shell profile for this is setting role1 , value = ALL.
Can please suggest or any idea i can make it with priviledge to administering the WLC, thanks
The firmware setting in use as below:-
1. WLC 5508 with firmware 7.0.222.0
2. ACS version 5.2.0.26
Noel
01-10-2012 08:14 AM
01-10-2012 07:19 PM
Hi Mejia,
Thanks for the reply !!!
I do according your instruction and found tihs log from the WLC.
*emWeb: Jan 11 10:57:44.401: %EMWEB-1-LOGIN_FAILED: ews_auth.c:2105 Login failed for the user:noel. Service-Type is not present or it doesn't allow READ/WRITE permission..
Anything i can tune on the ACS or WLC?
Please advice.
Noel
01-11-2012 09:35 AM
Hello Noel,
Have you confirmed on the ACS Logs that the user "noel" is hitting the appropriate Rule which assigns the Role1=ALL?
Can you shared screenshots of the ACS configuration (Shell Profile, Access Service Rule, Report Details by clicking on the magnifier)?
Will wait for your response.
Regards.
