How many spine nodes will be supported on ACI Fabric?
Hi Experts,
I want to clarify how many spine nodes will be supported on ACI Fabric now and future(maximum number of spines)? Because there are some different speculations about that. Someone says it'll be 12, others say it'll be 16 spines. Which  one is correct or others?
Thanks in advance.
Paul
1 ACCEPTED SOLUTION
Hi Paul,In the current
Hi Paul,
In the current release we support up to four (4) spine switches in a single fabric.  Future scalability numbers are still being worked on.
Zach
Hi Paul,
Zach
Hi Zach,Thank you so much for
Hi Zach,
Thank you so much for your answer. Could you roughly share when and how many spine switches would be supported? e.g 8 spines will be available in Q4 and so forth.
Yeah, I know it's not easy but I want to know the rough road map of ACI Fabric.
Thanks in advance.
Paul
Hi, Paul,As today and the
Hi, Paul,
As today and the roadmap as per my information, We are still looking at 6 spines in each fabric.
Number of leafs support has more importance which is 200 within one fabric in the upcoming release Q2'15. One fabric will also support approx 100 FEXs as well.
Anser
775
