ACE module redirect URL from HTTP to HTTPS
REUBEN CHIN
I've seen a lot of examples of how to do this, but either they don't make sense to me or there's something I'm missing within the understanding.  Hence I'm posting my question here.  (my apologies for the repitition in advance).
There is currently configuration already applied for normal load balancing of port 80.  I'm simply trying to modify this to do the redirect.
This is what I've already applied:
rserver redirect www.abc.com-RD
  webhost-redirection https://www.abc.com
  inservice
serverfarm redirect www.abc.com:80
  description www.abc.com-port80-RD-port443
  rserver www.abc.com-RD
     inservice
There's already a class-map created which I think I can use:
class-map match-all abc.com-CM
  2 match virtual-address X.X.X.X tcp eq www
The following text is what I think might be needed... but when I've added this it doesn't do anything.
policy-map type loadblance first-match abc.com:80
   class class-default
   serverfarm www.abc.com:80
policy-map multi-match POLICY
   class abc.com-CM
   loadbalance vip inservice
   loadbalance policy abc.com:80
   loadbalance vip icmp-reply active
Simply put, I just want users to go from a HTTP site to a HTTPS site.  There must be some kind of easy example by which to follow.  Any help would be greatly appreciated.
ajay chauhan
Level 7
Level 7
https://supportforums.cisco.com/thread/2079279
Have a look on given link seems to be same issue.
Ajay
In fact it's far from being simple regarding the exact behaviour you want.
Please post your whole config and tell us exactly what behavior you're expecting.
